Hello everyone. I own 2 TJs. One manual and one automatic. I recently swapped the transmissions between the 2 and just realized that they were geared differently. Now, I want to swap the gears also. Both have Dana 35s for rear differentials. I’ve been dreading it based on all I’ve seen regarding setting the gears up. However, someone just told me that if I’m doing a straight up swap, shims and all between the two Dana35s, I won’t need to do all the set up. Is this true? Can I swap the ring and pinion gears along with the carrier and just bolt it all back up? Or will I still need to get all the tools check all the settings. If so, would it be easier just to swap the whole rear axel assemblies between the two Jeeps? Any advice would be appreciated.
