Swaybar links
CMTJ
Jacksonville, FL, United States
I put the Zone 1.75 lift on and had a slightly hard time getting the links off. I messed up the rubber cups but did not think too much of it. Bolted all back up with no issues but now I have that clunk sound when I make a sharp turn. Should I have replaced them with 0-2 inch longer ones or can I just replace with new OEM ones?? Thanks
Depends upon what angle your sway bar is sitting at right now. If it's parallel or slightly above parallel to the ground with the current stock ones, you're probably good to go with another set of stock links.
