Was at Wally World and accidentally purchased the Valvoline 10w30 Max life synthetic blend instead of the typical Dino Valvoline. Has anyone used the Maxlife with good results or should I just go and exchange
Which one is synthetic, which is conventional, and which is high mileage blend?
What would "good results" entail?
Like extra unleashed horsepower?
I took it that he meant no problems with leaks.
On 5/24/19 you switched to synth.
Decided against it, maybe developed a leak?
On 7/22/19 went back to conventional.
On 11/21/19 put high mileage blend in it.
I don't see any relation between type of oil and how the 4.0L engine wears. Obviously, I am still using oil that meets the specs that Jeep said to use (API certified, correct weight, etc) and I'm not intentionally abusing it with incorrect oil.
