I fully get that it is on them. I also fully get that even though it is on them, it is also very dangerous, and the goal of those who understand should be to keep folks safer while they are doing something inherently dangerous.
Maybe I can clarify a bit more for others with an example of the typical 9500 lb rated winch.
They are typically supplied with a 5/16" steel cable/wire rope with a rated breaking strength of 9800 lbs..
The overhead lifting industry uses a 5-1 safety factor for the vast majority of the rigging and rigging components. In other words, if you want to use a shackle to lift a 4 ton load, a quality 3/4" bow shackle can be used and it has a Working Load Limit of 4 3/4 tons which is 1/5 of its rated breaking strength of 47,500 lbs.
The offroad recovery world comes along and sees the 9500 lb. rating and adopts it as the standard and then tells everyone that they should also be using it because the overhead rigging world is correct, so it has to be correct for winch recoveries. The glaring mistake in that logic is the winch does not have the same WLL or 5-1 safety factor. In fact, it doesn't have much more than a 1-1 safety factor on average if you believe that every piece of cable will break at the rated 9800 lbs or every 9500 lbs rated winch will pull at no more than that. In a perfect world, that is a 300 lb safety buffer.
The reality is, the average 9500 lb winch can't break a quality 7/16" bow shackle and by comparison, that shackle is miniscule when you compare it to the 3/4" bow shackle.
This pic shows the two sort of side by side for a comparison.
I have a few I keep around to show folks and not a single time has anyone said or understood they can't break it and emphatically insisted I was not correct.
