I'm installing the Morryde Tailgate reinforcement kit and have all but the last two hinge-bolts out.
The lower two that bolt the hinge to the tub are the problem likely because they are the only two that are exposed to road corrosion.
I'm 4 broken T40 bits into it and although I've not damaged the torx bolt head(yet) I've made no progress getting those two to budge.
So far I've heated it w/Mapp gas to the point of starting to damage the paint around the hinge and I've tried a 1/2" impact(as gently as possible). I also tried one of those hand-impacts you whack w/a hammer. This was after cutting the paint around the bolt head etc...
The only thing short of a cutoff wheel I haven't tried is one of those black "impact rated" T40 bits. The busted ones are a mix
of regular Craftsman, DeWalt and HF's best. I plan to stop by a parts house on the way home today and try to get an impact bit but before I do I thought I would ask if anyone thinks that might really make a difference or just be another broken one in the pile?
If not, I'll just go to the cutoff wheel and destroy the hinge or drill it out and retap it.
As I side note: I'm really impressed w/the quality of the Morryde kit...nice thick steel plate. Wish I cold actually install it
Edit: I forgot to mention that none of the bolts I already got out had any remnants of locktite on them.
