Tapered Tie Rod insert?
Ahoragi
My dana 30 knuckle has an expanded tapered hole for the tie rod. I have to use washers to raise the nut to tighten to specs. This also crushes the grease boot causing grease to leak out.
I have HD stock-style steering and trying to avoid buying another knuckle. Is there a tapered insert that will return the expended tapered hole to original size?
Thanks
That would work and it's a very good mod. Just know that also requires that the driver's side lower antiswaybar link be relocated which would require a little welding.
