Temp gauge isn't working on 91 YJ
CMTJ
Jacksonville, FL, United States
My sons new to him 1991 YJ 4.0, I know, I know its not a TJ but was all he could afford. Temp gauge not working. I ground the wire and it makes the needle move like 1/8 inch then needle goes back to the left. Would it be the gauge or the sensor on the head?? Thanks
The sender is supposed to have the following resistances measurements to ground... 1365 ohms=100 F. 115 ohms=210 F. 55 ohms=260 F.
Shorting that wire to ground should have pegged the meter. I guess either the gauge is bad or the wiring between the sender and gauge has a problem. There's a connector on the left side of the steering column, the violet wire with the yellow tracer leading into and out of that connector is for the temperature gauge. I'd unplug & then reseat/plug back in that connector to see if it makes any difference. Hopefully the connector is just a little dirty or corroded.
Hows it going guys 97 tj auto 4.0 .....upper rad hose popped on me so I figure change out my therm and sensor while I'm at it ...replaced all 3 items and now my gauge won't go past 100 maybe slightly above it but that's it and now a check engine please help!
I'll post the code as soon as my buddy comes with his handheld........as far as the parts both from autozone not OEM and the hole facing up
Reactions: KCsTJ
P0118 - Engine coolant temperature circuit, high input. Not sure what this code suggests, whether in the circuitry or elsewhere.
I would reinstall the temp sensor that was in before the upper hose blew.
Try that and see if you get a normal temp reading
Try wermopar.com and there's a couple other sites I can't remember
On line may be your best bet , I'm still kinda working my way thru learning how to order the right parts on line so I'm not the best to ask in terms of true OEM parts .
Others may chime in
Glad I found this. Replaced the CTS with one form local autoparts store and still kept getting p0118. So i thought maybe Thermostat was stuck open so attempted to replace that and cracked it in doing so. So had to get a better mechanic than I to fix. Hopefully it was something as simple as using OEM this whole time. Thanks! Will update
I have a 2004 TJ that just had a whole new oil pan & gasket put into it. I checked engine oil ( brand new ) and drove it around town. Jeep is working great and all gauges were fine. I just got a check engine light to check gauges and the oil temp is suddenly not working. I saw no oil on the ground & checked engine oil and its fine.. What should I do next?
Oil temperature? Do you mean oil pressure or engine temperature? If you meant oil pressure gauge, I'd be suspectful of a problem with the oil pressure sender mounted close to the oil filter.
weird let the jeep cool. Did an engine cluster test. Started jeep and oil pressure gauge is working and check gauge light is gone. That has me nervous.
