Over the last couple years my LJ has seen less and less road/trail time. Part of this has to do with significant life changes, which makes a 2 door not practical for regular use now. As a result, I'm beginning to consider moving to a 4 Door JL, which I know would get more use. Before making the leap, I'd want to sell my LJ, which I've built over the last 7 years to be the Jeep I always wanted.
Having sold modified and stock Jeeps, I know what I'm in for trying to sell one like mine. I also know that tastes are different and some may not like the parts choices, but each part was picked for a reason and no corners were cut. That said, based on the description below, what do you think would be a good place to start in terms of price?
2004 Wrangler LJ with 131K
Automatic
Cruise Control
Full & Half Doors
The Jeep has always been garaged and has zero rust. Here's a breakdown of what's been done:
Interior:
Bartac Front Seat Covers
BedRug Carpet
Upgraded Bluetooth Stereo, Speakers, & Subwoofer
Rockhard Interior Cage
Tuffy Full Subwoofer Console
Drivetrain:
Automatic with B&M Stacked Plate Transmission Cooler and Transmission Temperature Gauge
New Cooling System
New Brake Pads, Calipers & Rotors
New Oil Pump, Rear Main Seal, Valve cover & Oil Pan Gaskets
Dana 44 Disc Brake Rear With 5.13 Gears, Factory Locker, & Superior Axles
Dana 44 Front With 5.13 Gears, Factory Air Locker, Reid Knuckles, Warn Lockout Hubs, & Dutchman Axles
241 RockTrac Transfer Case with Cable Shifter
Advance Adapter RubiCrawler, With Twin Stick Shifter - Provides 4 Crawl Speeds (1:1; 2.72:1, 4:1, & 10.88:1)
Armor:
Savvy Aluminum Gas Tank Skid, Along With a New Bosch Fuel Pump
UCF Aluminum Transfer Case Skid
UCF Aluminum Engine Skid
Metalcloak Full Corner Armor
Metalcloak Rocker Guards
Metalcloak Front & Rear Fenders, With 6" Flares
Nth Degree Rear Differential Skid
Bumpers:
UCF Ultra-High Clearance Steel Front Bumper
Superwinch EPi 9.0 Winch With Synthetic Line
UCF Aluminum Rear Bumper with Tire Carrier
Suspension:
Metalcloak 3.5" Double Adjustable Aluminum Short Arm Lift
Metalcloak Front & Rear Trackbars
Metalcloak 6Pak 13" Travel Shocks
Artec Lower Control Arm Mounts
Currie Correctlync
Wheels & Tires:
Walker Evans Beadlock Wheels
Mickey Thompson MTZ P3 35x12.50R17
Lights:
All Interior Lights, Dash and Overhead, replaced with LED
Headlights, JW Speaker LED
Automatic
Cruise Control
Full & Half Doors
Interior:
BedRug Carpet
Drivetrain:
New Cooling System
Armor:
Bumpers:
Suspension:
Currie Correctlync
Wheels & Tires:
Lights:
