Tire date codes, how to read them
Tires do have a shelf life period, but how long is affected by many different circumstances so there is no exact time limit on how long they will last. Rubber deteriorates even when stored out of the sunlight it's an unfortunate reality. All tires sold for commercial or personal use on any kind of vehicle have a "TIN" and the primary function of the TIN is just like any other product that is made in "Batches", the last 4 numbers of the TIN are the date code (date code is usually only on 1 side or the other of the a tire while the rest of the TIN is on both) NHTSA is more interested monitoring how may tire failures in each batch than they are how old each batch is. Here's a quote from NHTSA
"The tire identification number (TIN), which must appear on virtually all new and retreaded motor vehicle tires sold in the United States, plays an important role in identifying which tires are subject to recall and remedy campaigns for safety defects and non-compliances."
That doesn't mean that it's safe to ignore a tire that is getting old. Tires can and have lasted far longer than 10 years and still been functional but it's not the norm. Dry rotting is the major concern with older tires, but that isn't limited to the tire. As OP mentioned valve stems are just as susceptible to deterioration as tires. In the case of his story the tire wasn't the failure problem.
Bottom line, unless you're confident with your knowledge of tires, take your tires in to a credible and trusted tire service center and ASK them to evaluate the tires, valve stems, and date code on your tires.
  • USA Proud
Reactions: CharlesHS
After reading this post I went out and looked at my tires. They are six years old. Less than 15,000 miles on them and lots of tread left. I took some pics and see some cracking. I was looking for an excuse to get new tires/rims. My current rims are as 17s (tires are Load E). I think I just found a legitimate reason to purchase those 15 inch rims. Anyone disagree?
I guess it's as good an excuse as any!! They'd probably last a while longer if you didn't want to replace them... You could probably sell them to recoup some of the cost of new, whether you disclose their age or not is on you and your conscience...
I’ll have to disagree to some extent. I learned by being an RVer that you will never wear out the tread on trailer tires before they fail due to age. ‘Usually by about 7 or 8 years even if there is no sign of cracking or dry rot. Our Jeeps are very much the same way if they aren’t daily drivers. My personal tolerance for this risk is 6 years. Short wheelbase lifted vehicles like ours wouldn’t do well with a blowout at highway speeds. Do what you want, but a set of tires is cheap compared to what could happen with a tire failure.
Reactions: Mudflat
Now that's interesting.... How is it I replied to your post before you posted???
Oh ok I see now your post posted twice.... hahaha wheeewww thought i was losing it for a second!!
‘No disagreement here. ‘Glad I could help. You’re right to ditch the E load range tires. Jeeps should have no more than load range “C” tires.
Many tire shops will not rotate tires that are 6 years old because of the risk. ‘Glad you’re playing it safe.
The Firestone Destinations that I have installed on my '01 TJ 4.0L have the date stamp on the side which has the white lettering. The white letters were installed on the inboard side; these numbers indicate the 38th week of 2019.
