So I'm doing the oft recommended "Pull the springs and jack the axle" test to see what fits, what hits before anything is modified. This is a completely stock steering, shocks, control arms, track bar, bump stops, everything. Tires are 33x12.5 on a 15x8 rim with 4" BS.
When it's jacked up til bump stop, wheel straight, no issues, plenty of clearance.
When I attempt to turn to full lock with the tire stuffed, the tire rubs the corner of the spring tower and the stock sway bar at about the same time. But there is still a considerable gap between the steering stop and the stop bolt. Is this just the nature of wider tires and I should expect to lose some turning radius to keep things from hitting? Do you extend the steering stops, or just be mindful to not crank the steering when stuffed?
