For the shifter:
One of the TJ's I converted to Magnum V8 power was an automatic so I robbed a junkyard 2003-2006 TJ/LJ for the correct shift bezel and used that.
On the other it was a manual transmission so I again went to a Jeep junkyard and purchased the complete shifter mechanism and cables out of a 2003-2006 TJ/LJ for the shifter. Fits and works like a charm.
BUT!!! I used the arm, (lever on the transmission shifter shaft the cables connect to) off the Jeep transmission and adjusted everything to fit, worked perfectly.
RR
RR
