I haven't looked at his jeep but he 100% helped me understand the process when I did this to mine months ago. He helped me a bunch to understand what the heck was going on. Actually, I'm pretty sure he sent me a video early on, but it doesn't matter since I've done this myself. I'd be happy to provide you with a video if you want me to.You haven't done shit. Post pictures of your setup in detail fuck tard.
Summary:
I have two white/yellow wires (one to the turn signal and one to the side marker) that run in the wire bundle on the top of each side of the engine bay.
I put the resistor on the white/yellow wire that goes to the side marker. This dims the running light output of the marker so that the turn signal function (that does not contain a resistor in series will blink at a higher brightness). If I didn't do this, I'd be running constant brightness that will be the same as my turn signal brightness so it won't blink at all. I know this to be true because this happened to me. I then dialed it in further by choosing the resistor value that dimmed down the running light so that it still matched my front lights but was also differentiated well enough from my turn signal (meaning not so bright that it's hard to tell the difference).
