TJ motor swap
Jakekk1
Saint Robert
I am thinking about doing a swap on my 06 rubicon. I am thinking 5.9, but I’m trying to figure out if that is a swap that is worth while. Another thing is I don’t know what transmissions want to run yet, open to ideas there. Last thing has anyone tried using the stock 4-1 tcase with this much power?
Complete 4.8, 5.3, or 6.0 can be had much cheaper and with a lot more aftermarket support for it as well. 4L80E trans or even a stock TJ trans with a 241 will work just fine. Novak and advanced adapters sells adapters to make them fit.
definitely do all your homework before diving into this swap. But it is well worth it.
Reactions: Jakekk1
X2. This is definitely the way to go over the 5.9, and I’m sure most will agree. It can be done for much cheaper, and I believe there is more aftermarket support for those engines most likely.
+1 vote for the LS
If you're going to V8 a 2006 TJ, the logical choice is a 5.7L HEMI swap. Native electronics makes it easier to use than the older 5.2/5.9L Magnum V8, federal and 50 state emissions legal as well. The golden rule on engine swaps is equal-to or newer than the vehicle it is going in along with same weight class as the donor. That is a light duty 1/2 ton pickup, SUV or a passenger car as the donor, not a heavy duty truck. The emissions controls and ECM are similar in the early HEMI V8 Chrysler products to a 2005-2006 TJ so that makes sense to do. The Magnum V8 was discontinued in early 2003 so it isn't even really a contender for swapping in late model TJ Wranglers. Best save the Magnums for pre 2003 TJ's. Although I agree "technically" the best V8 made is a GM gen 3 and up, it's more electrically complicated to integrate into the TJ and there are some hidden costs there not discussed in this thread such as gauges etc. I have swapped GM Gen 3+ power into Jeeps but always reserved for earlier models due to simplicity sake like the CJ-7's, 8's, YJ Wranglers pre OBD 1 that are pre 1992 electronic gauges etc. I have had very good luck with them, I just wouldn't do it in a TJ without understanding the full changes required and keeping in mind federal government emissions laws. This even if there is no testing in your region of the country should you want to sell or move sometime in the future.
RR
Reactions: Jakekk1 and Chris
Thank you for all the insight on the swaps. There are so many different ways to go it’s just choosing the best one.
LS is cheaper and easier (for parts and support)
If you need all your smog stuff go Hemi, same year or newer as your jeep. Preferably out of a SRT8 grand cherokee
