So I go out to check the size of the bolts that hold the sway bar to the sway bar brackets on the axle. The REAR sway bar that is. I can not find the right socket. I'm sure its not metric, but i start trying anyway and come to find out i have to use a M15 wrench to take it off. So I looked around the net to find out its not only M15 but the bolt is a M10-1.50 x 35. Have yall found the same to be true?
