Hi fellow Jeepers!! So my beloved 03 TJ Rubicon has a locker issue. Rear locker light stays flashing. Rear off the ground. Push locker button. Pump runs then shuts off. Ok normal. Go to turn the rear wheels. The turn together. Ok good. Then I had someone hold the opposite wheel on the rear axle. They could hold it as I spin the other tire!!! WTH so it's only partially engaged I'm assuming. Any words of advice on the issue?
Thanks
Thanks
