ejay
There are plenty of videos on YouTube of Jeeps plowing through deep snow without issue. And plenty more of them not doing well at all on 1" snow covered and ice covered roads. Chains help...I guess.
And experience, 4x4 does not mean everyone can just drive like it is dry. There has to be some s ow/ice experience and common sense. You might still start off decent but stopping and turns and such will definitely be impacted by the white stuff.There are plenty of videos on YouTube of Jeeps plowing through deep snow without issue. And plenty more of them not doing well at all on 1" snow covered and ice covered roads. Chains help...I guess.
Although I have an LJ, I haven't had many issues at all when it comes to sliding around. I just got Goodyear Duratracs last month and am salivating at having to go to work at 8am tomorrow
I had to drive last night for 3 hours with 1" of ice on back roads and lots of trees down. Good luck with you Subaru lovers trying to get over a downed tree...... or a beer can without scraping.
Some tips:
Keep it in 2WD unless you notice the rear tires are slipping. Since the TJ has 4WD and not AWD, any time the car turns in 4WD, the front tires will slip relative to the rear tires, resulting in brief losses of traction. You can shift from 2WD to 4Hi and back at any speed as long as you are going in a straight line and the wheels are not currently slipping. In changing conditions, I will constantly be switching in and out of 4Hi.
In ice and slick surfaces, consider tire chains. Tire chains give impressive traction in all directions, more so than studded or winter tires.
Always put the tire chains on the rear axle if you are only doing one axle. Putting them on the front and not the rear can change the stability from an understeered setup to an oversteered setup, meaning in a loss of control you would spin out instead of just sliding and being able to correct it. Tire chains on all four tires will provide the best overall performance.
Turn the stereo off so you can hear what the tires are doing. You are your traction control system. If you can hear a tire slipping, you will know to let off on the gas. You can often get audible cues that a tire is about to slip as well.
If you drive a stick, keep your RPMs lower than normal in shallow snow and ice. This reduces the available torque and reduces the odds of applying too much torque and breaking traction. In deep snow you may need to rev higher for power.
On of the biggest issues is weight bias. The TJ is a rear wheel drive vehicle with the ability to power the front axle also. This combined with a weight bias well to the front makes it harder in snow than a front wheel drive or a front wheel drive that can also power the rear axle.
And then the tires. For ON-road driving in winter conditions a mud style tire is terrible. Small tread blocks with a lot of siping is what is needed.
Almost all A/T tires have shifted away from their initial design. Folks want them to function more like a M/T and look like them too. A tire made extra rugged to prevent chipping uses the wrong type of rubber to be effective on poor road conditions. This has been the reason I have championed the Cooper AT3 tires. They are designed primarily for on-road conditions like this. There certainly are others, but even Consumer Reports gushed about them when they came out a decade or so ago.
In the other hand.....
I've got 3 feet of snow outside my house and it is still snowing hard and blowing around and setting up like cement. Nothing short of chains (or an agricultural tire) will do well in this mess.
The more weight you can put on the rear axle the better you will be in crappy weather. Even heavy rain and flooding.
But this is (near me) heavy greasy snow, and no car or truck will be making this storm look easy. Good luck all. We'll all need it for the next day or so.
My Outback had ~9" of ground clearance and frequently passed stuck Jeeps, SUVs and pickup trucks on back roads in Northern Arizona...My subaru's had the same ground clearance as a stock TJ...
And 2in of lift actually gave 2in more clearance, unlike a solid axle vehicle.
A modestly built pop-top RamCharger (my personal choice), K5 or Bronco...But name another vehicle that can do all of that adequately. And that’s the beauty of a TJ.
Until the TJ came around (and these died out!) these were the "King of Things" (meaning they could do anything). Honestly, if the Big Three had continued to make 2-door full-sized SUV's like these, I don't think the TJ would have grown in popularity as much as they did between the YJ and TJ.
These rigs had ~106" of wheelbase, were about as wide as a modern JK/JL, were comfy despite being on leaf springs, could haul all sorts of gear, had ample power and torque, but were still small/civil enough to drive around town or on tighter trails.
