Its late writing this and i work all week so i need input. I went to go to work today and the 4.0 wouldn’t crank. Its a 2002 jeep wrangler 4.0 3 speed auto. I swapped the starter relay with the horn relay. No luck. It clicks but wont crank. Hooked the starter directly to a jumper and it cranked perfect. Thought about it being the ignition switch? But it wouldn’t click would it? The battery is very new. What could the culprit be? Anyone have this issue? The jeep is in very good shape so a wiring issue would be my last guess on the issue. Safyety switch? Solenoid? I just dont know and really need help because i daily this and dont have much time to work on it. Thank you
