Sorry if this has been addressed but I haven’t found an answer yet.
Hello, Leo here. New to the forum but have read all I could find on the issue but it hasn't helped. So here we go. I purchased a nonrunning TJ with 4.0 manual xmission. Previous owner stated it started to idle poorly, after awhile it quit running and has sat for a long time. Don't know how long.
Battery good, grounds to body and block good, fuses and relays in engine power distribution center good, engine cranks over good, 145 to 150psi on all six cylinders, 47 psi at fuel rail. Old coil rail sparked on 1-6, and 2-5 but 3-4 did not. Replaced coil with new MOPAR coil. same 3-4 no spark. Ignition coil driver in PCM out? Possible, but why won't the rest fire off? Fuel injectors 1 thru 6 check with noid light and pulsing. Both fuel injectors and coil get power through ASD relay and fuse 28 so power is good. Two coil packs are firing so crank position sensor is working... Any suggestions? Yes, good fuel with seafoam in tank. New plugs as well. Has darn SKIM but no key light flashing. Thank you!
