Hmm mines a 98 I just assume everybody drives a 98 haha49 +/- a few psi is correct for 97 to 04 TJs. 58 psi +/- a few psi is correct for 05-06 models.
The 60 psi you measured is excessive for your '98, I wonder if the pressure relief valve inside your fuel pressure regulator might be hung up.Hmm mines a 98 I just assume everybody drives a 98 haha
No, I tried starting fluid to no avail. That’s why I thought it was the PCM or SKIM. Still think it should run on the sparking four cylinders but maybe computer manic won’t let it. Got some throttle body cleaner today so I will add that task to my list. Thanks for the info from everyone. Takes a village.... just don’t like being the idiot. Lol. I will keep you posted.Does starting fluid or carb cleaner in the intake have any effect?
Thank you. I have confirmed spark. Coil pack was not firing 3 & 4, installed now MOPAR coil pack. Same thing. Found broken wire. Repaired. Still won’t light off. Yes new plugs.If you spray carb cleaner / starter fluid in as you were cranking it and saw no affect, then you must be missing a spark. You may have a fuel issue too, but I’d work on the spark first. The PCMs are pretty resilient, so I’m guessing is some broken (or chewed through) wire somewhere.
I meant to say And yes, there are no codes.Huh? "As yes"?
