So, you got a new battery (from where) and they replaced it 5 months later? That’s somewhat odd. When they tested it they said it was bad?
I can’t see if you have a manual or automatic unless I’m misread if the profile. Manual I would find a way to push start, if it runs then feels you probably starter.
I’m assuming they test a battery before replacing, so you mist have a battery drain, but I’d still start with the simple. So you turn the key and zero, no click at all.
I would tap the starter with a hammer a couple times and try again.
Then I would jump over the starter solenoid and see if it engages. So basically find out if the starter works, since you have a good battery.
Then I would check and make sure every battery cable Connecion was clean and tight, especially the ground (negative).
Then if it’s a manual, the clutch safety switch, then the ignition actuator pin.
If you have a volt meter and you put it at the starter, and it gets juice when the key is turned, then I would focus on starter.
If no, I would start focusing on the clutch safety switch or the actuator pin.
