I recently got a great deal on this Kargo Master roof rack for $100.00
Its discontinued but I was able to find that the carrying capacity is 500lbs, however it'd requires you to drill two 5/16's holes in the tub where the mounting plate are (by the tail lights). Currently the plates are connected to small 10mm bolts that are used to mount the tail light, three on each side.
I would like some feedback on the necessity of drilling holes when the most I would carry is a canoe in the 70-100lbs range and I don't plan to have the rack on year round.
I've attached photos of the mounting plate. Please take a look at the side view, you can see the mounting plate is not fully against the tub; you can see a small opening. When I apply pressure there is a little bit of play that allows me to push in the plate closer to the tub.
Would drilling a hole on an LJ be a big deal when it comes to affecting the value? its super clean and unmolested. I plan to have it for the long run but I'm still mindful about maintaining its re sale value if I ever needed to. More importantly do I risk damaging the tub by not securing it with the extra bolts.
