Tool deals
I have four "professional" Stihl saws from a small top handle for in-tree work to a behemoth that can fell a very large oak or elm without issue. I love them all and won't be replacing them with electric saws any time soon. I don't see the inconvenience of a good two-stroke saw that some of you see, but I'm a two-stroke engine lover, so there's definitely some bias there. BBRRRAAAAPPPPPP! :ROFLMAO:
Back when I lived on acreage there's no way the battery options would have cut it with all the pines in the CO mountains without dozens of batteries. However for the limited use I need in suburbia and occasionally on a trail, the m18 fuel stuff is enough for me currently.
I'm a big fan of the Stihl chainsaws for the heavier workloads, none of the neighbors had any other brand that lasted as long or had as much power - most of them converted eventually.
Maybe not replace them, but if you grab that little M18 Hatchet, no matter how much you like a gas saw, you'll find yourself more than a bit pleased with the absolute ease and convenience of being able to make a couple of cuts (or more) and the only thing you need is a battery (that you already own).
Where it really shines for me is trimming branches from fallen trees. I grab the M18 saw and M12 pruning shear. I can make quick work of cutting off the branches. Plus, I'm not worn out from handling a heavy saw. As you said, it's not a replacement, but it certainly has its place!
Reactions: John Cooper and sab
Anyone who owns greenery in most any form from small bushes to large trees that need pruning from time to time and DOESN'T own that little pruner is simply not paying attention.
I have the smallest “professional” Stihl I bought brand new 6 years ago, it’s getting listed when my M18 comes in this week. It’s hard to want to deal with gas when I use it once a week for 10 minutes max. Also selling my blowers as well and just using an M18
https://www.homedepot.com/p/Milwauk...bo-Kit-w-8-0-Battery-2-Tool-3031-21/330529557
Mine was a pro model too.
I've still got my chainsaw and will likely not get rid of it but I need to add some gasless options there too.
For suburban or urban residential use, I certainly wouldn't own four saws. In fact, way back when we were first married and lived in a suburb, I made due without a saw. The first Stihl I bought was their professional top-handle saw. It's nice and light, easy to handle, and punches way above its weight. It worked for many years for me before I bought saw #2. That said, I can certainly see the K.I.S.S. appeal with the cordless electric saws. My elderly neighbor has the M18 one. I've used it, but I still prefer my Stihls, personally.
Is the M18 Hatchet worth it if I have the M18 Super Sawzall and occasionally use in the situation you describe? I've used that to quickly trim one or two limbs before and it works for that. In fact, I posted recently about repairing an underground rainwater pipe. I used my M18 Hackzall to cut the tree roots that had grown around the leaky pipe. That's a situation where I won't use a chainsaw because the dirt and rocks will dull a chain quickly.
Reactions: Tob and rasband
You are acutely aware of my fondness for my Dynabrade die grinder. I recently picked up the Milwaukee newest M12 version. I haven't used the air version since. I will when I need a cut-off wheel for frame work but everything else has been more than readily handled by the battery stuff. Point being, some of this stuff is good enough you find reasons not to fuck with gas, cords, or air hoses.
If I send over a little sachet that mimics the smell of a 2 stroke running, will that help? You can hang it around your neck when you grab the Hatchet.
Maybe some day when my corded stuff wears out I’ll switch to battery. I just have battery drills and drivers. As of now my Frugal Mid-Western self can’t discard a perfectly good operable tool. Even when I’m in a area with no power I just bring out my Honda inverter.
My new neighbor was using a battery string trimmer to clear the 2’ tall weeds on his 1/2 acre property that’s been neglected for years. I came out with my 22” 6.5 hp wheeled string trimmer and got it cut down in 10 min. Every tool has its pluses and minuses depending on the job to be accomplished.
https://www.lowes.com/pd/DEWALT-7-1...liding-Compound-Cordless-Miter-Saw/1002979942
The tool deal man. Have you seen any for a Milwaukee shop vac dealio? Mine just leaked out all the magic smoke. Cordless seems nice
Unsure of deals but there was some debate as to whether one should acquire the regular or the Fuel version in the 2ish gallon size. When it was mentioned that the Fuel was a whole bunch more sucky, I bought one as a test. No contest and my non Fuel 2 gallon left here with a quickness as a gift to a buddy. I don't give a shit about the Packout function, but the rest of it is stellar. It only has one quirk, there is a little cone adapter that has to be stored in the trash section.
Home Depot has the fuel version for free with purchase of either 2 6.0 batteries and charger or 2 8.0 Forge batteries with charger for Father’s Day special. If you need batteries it isn’t a bad deal.
Good tip I will make sure I get the fuel version.
Do you have a link for that? I could use some batteries
