I'm replacing my entire suspension after the Jeep frame has been up on jack stands and the axles removed so there is no 'reference points' as far as axle placement.
I'm putting in a Currie/Savvy full JJ & all adjustable arm kit.
I have all arms in and the springs and I'm working to try to dial in the pinion angle for each axle (and confirm they are square to the Jeep).
My reading of the guidance was to center the axle based off full stuff. This makes sense front to back but then the side-to-side is still way off. I've also read to get the arms length set (pinion & squareness) and then put in the trac bar.
I'm at a loss on where to go as installing the trac bar when the axles were at full stuff has them 1-2" off side-to-side at ride height.
Before I try to get the pinion & squareness down, am I best to correct the trac bar to space the tires/axles equally? Or do I remove the TB entirely from the install now and just get the pinion & squareness dialed in?
How can you confirm the squareness if the axle/frame references will change after you set the arm length to get the axle centered?
