Hey guys,
I'm rehashing this thread with hopes on some recommendations for a rear bumper, and wanted to get your opinions on a custom setup I have mocked up. I am by no means an engineer, and if what I've come up with is unsafe or precarious in any way, please don't hold back on telling me so. The last thing I want to do is compromise the structural integrity of my rig. Having said this, I think what I've come up with will work and it will give me an opportunity to do some beginner-level fabrication.
To begin, my goal is to end up with a rear bumper/plate setup with a hitch receiver, while preserving as much of my current departure angle (with just the cross-member and no bumper at all) as possible. I'd like the hitch receiver to be able to take 500 lbs of tongue weight from a hitch basket, and tow a ~1,000 lb jet-ski trailer. I am familiar with the various aftermarket bumpers that place the receiver in the conventional (outside) location relative to the crossmember. From a design and installation perspective, this is the simple way to go. Furthermore, my design below is incompatible with TJ's, and being the relatively rare Jeep it is, manufacturers I think tend to shy-away from making strictly LJ-compatible parts.
With the LJ, however, I have two rear crossmembers: the forward one is what the tank mounts to, and about 4.75 inches behind that sits the rearward one. This is what the bumper mounts to, and I'm sure also adds some rigidity to the frame.
My design takes
GenRight's TJ/LJ Rear Bumper Plate with Tow Points and adds a standard hitch receiver on the inside of the plate. I would pick up a generic ~3.5" long receiver shank from a trailer supply store, cut a 2" square hole in the GenRight plate, and weld it on the inside. Additionally, for some added strength, I would gusset it on either side with some 1"x2" square tubing.
To install this, it would require cutting and removing the most rearward crossmember. That said, GenRight's beefy 3/16" plate combined with my gusseting, I think this bumper should be plenty strong enough to handle some serious pulls without the factory crossmember present. Below are some photos of what I'm working with real estate wise, where I would cut the crossmember on either side, and a very-poorly illustrated top-view schematic of the finished product. It is not to scale, but provides a general idea of the design.
If chopping the rear crossmember is a bad idea, I could also simply cut a 2" square hole in it that would accept the bumper's receiver. This would eliminate the ability to gusset it, however.
What do you think...am I crazy or is this doable?
