I have a 2006 TJ with the 4.0 motor and 42rle transmission. I removed my transmission transfer case crossmember/skid plate to clean between it and the frame, remove any surface rust there and repaint. I need to make sure I am using the correct torq spec for those 6 skid plate to frame bolts. I think it is 55lbs, but I have seen other lists of TJ torq spec that say 30lbs, one said 33lbs. I'm pretty sure some one here told me 55lbs before. Could one of you please confirm?
Thanks
Thanks
