I have a 1998 tj wrangler in the future I'm going to be swapping out my transfer case because I plan on putting a ax-15 transmission along with a 350 sbc or possibly a 4.0l. my current transfer case is a 231-j the case has the slightest Hair line crack by the check plug I tightened too tight when I changed the fluid I put jb weld on it and it's been fine... I bought a 1995 xj case to replace it because mines cracked and It has a true neutral like the tj case has also needed a 23 spline long input shaft for the ax-15 transmission instead of buying just the input shaft and another case I thought buying a 23 spline 231-j t case was a good idea... I may have goofed and at the time I was not aware the xj cases are clocked I have a slight understanding what it means but I'm not sure if it will effect me or not.. I have a 1 in transfer Case drop kit a tom woods double cardon drive shaft and a sye kit working on getting adjustable upper And lower control arms... do I need to be concerned with the clocking of the xj case or will it just be a direct Fit ? Would i need a ax-15 out of a 95 xj to make it work ? I'm also new to the jeep world and am trying to learn as I go so if this is a dumb question I do apologize Lol.... on another note I'm leaning more towards The 4.0l swap for several Reasons but I've been told and read I need to get a engine and trans from the same year as my current Tj so if I need to just sell the t case from the xj and buy one with 23 splines from a tj I guess that's what I'll have to do... hoping someone can chime in and help out
