Thanks man I’ll have to try that this weekendI’m going to give you the advise someone else told me… clean the heck out of it with degreaser and then brake clean. Let it dry off, and then get some gold bond/ spray on body powder (comes in a aerosol can) and spray the heck out of it with that stuff.. it will powder it white and allow you to see exactly where the leak is coming from
Do from the ujoint back… looks like it may be leaking from behind the pinion nut and slinging onto the muffler. Most likely leaking elswhere as well.
ThanksIt could be the seal on the sye housing but as said you need to clean that area before you know for sure
This is some very beautiful advice!I’m going to give you the advise someone else told me… clean the heck out of it with degreaser and then brake clean. Let it dry off, and then get some gold bond/ spray on body powder (comes in a aerosol can) and spray the heck out of it with that stuff.. it will powder it white and allow you to see exactly where the leak is coming from
Thanks, I’ll look into itIf you have ever changed the speedometer gear it's possible the the big O-ring that seals its housing to get nicked and start leaking ATF. That happened to mine and it created a mess.
