Currently have a 231 in a 4cyl that will pop out of 4low causing the shaft to spin inside. I have a cable shifter and is adjusted properly and when it pops out of 4low it sometimes is very difficult to get it both out of 4low or back in. This also results in the input shaft on the tcase to move so that the rear output seal on the trans begins to leak. It will even pop back in 4low (shifter engages both by the feel and indicator) and sometimes still spins the shaft as you can hear it inside but doesn’t move the jeep. I did rebuild it a long time ago and even put a 1.25 chain which was causing some of the problem but then I swapped it back to a new 1in wide chain and the problem is still persistent.
I’m assuming I failed to install everything properly when I did a full rebuild a long time ago. Is there anything that I should look for specifically? Should I just pull it and try and see if I can find it through different trials?
Open to any thoughts or suggestions to point me somewhere when I pull it.
