Hello folks. I have searched for this and can’t find anything straightforward. I have ‘04 TJ bought about 2 years ago, still finding things the previous owner did, I.e., Geri rigging etc.
Driving today started smelling burning, smoking, didn’t smell like engine oil or radiator, stopped but couldn’t find anything. Then started getting transmission slipping and barely would go. No fluid on the dipstick. I had a quart of fluid with me, put it in and made it to O’Riellys and bought some more, added a quart and that got it to top end of the dipstick. Started driving trying to make it home, about 4 miles from there slipping really bad but I could not pull off the road, very little shoulder and deep ditches on both sides in the middle of nowhere. Kept going, engine rev, then trans would engage briefly for another 50 yards or so. Did this for about a mile until I could pull over and call for a tow.
Got under it when I got home and saw one of the hoses from the trans to the radiator was a plain rubber hose, not preformed and was very close to the main fan pulley , only about an inch clearance between the hose and the pulley. Apparently vibration caused it to rub a hole in the hose, pulled the fluid out and fan blew it everywhere. Likely transmission is shot but I’m praying not.
I’m trying to find the proper hoses that go from the radiator to the steel lines , I assume they are preformed or routed in such a way to avoid being that close to the pulley, but I can’t find part numbers or good diagrams. I will get another plain old hose tomorrow on it and fill the fluid just to test and see if the transmission is fried but I need to have the right hoses and correct routing so this doesn’t happen again.
Any help is greatly appreciated!!!
