Today I removed the frame from both diffs getting ready to sand blast the frame and do some rust repair. I am having difficulty with one bolt which is the upper rear track bar bolt. I got the nut removed from the bolt no problem and now when I try to spin it out it the bolt will spin but only bends the track bar frame mount backwards towards the head of the bolt or rear of the vehicle and the bolt won’t back out and is still extreamly snug to the frame mount. I have tried to get a screwdriver between the frame mount and bolt head but the clearance is too tight. I also have used pb blaster and heat with no luck and tried a sawzall. The sleeve also seems to be rusted to the frame mount near the bolt head and I had no luck cutting through it. I have also beat the hell out of the tip of the bolt with a small sledge and hammer trying to push it through but that’s not working either. I will post a few pictures tomorrow because it’s raining outside now. But any suggestions or help is much appreciated.
