The single best mod for least amount of money spent for the greatest benefits.Everyone be hating on the small lil BL, just a small trade of function over form .
Agreed, you have to look for it.I really don't understand the hate toward a body lift either. Ok, 3 inches? Sure, hate away. For an inch though it gains you so much flexibility for stuff under the Jeep that it really makes sense. Also an inch is barely noticeable, unless you know what you're looking for.
Holy Flares Batman. Looking forward to your flates after the trim.Right now with the AEV HighLine I run 33s on stock steel15x7 spokers and a stock Rubi suspension, no lift.
Next mod will be to trim the 6" AEV flares down to 3".
If one could weld, you could use something like the https://genright.com/products/universal-transmission-crossmember-kit.html and be able to gain about 2" of clearance without moving the case at all. Looking at mine, it would probably need a new, smaller muffler but other than that, everything else would stay as-is. Not a true tuck, I get that, but it certainly gains much needed clearance. You also do not need to hold up the case/trans for skid removal since the skid would then be separate. I need to learn how to weld
Won't be for a while but sounds good.This is my plan, once I figure out my vibe problem. I can weld, and have access to a welder at our shop. It's only a 2 hr. drive away for you buddy. Let's do it!
Ohhh, I want to see photos of this when it happens.
Score! I've seen simular mounts that were custom fabricated. That looks like it just might work pretty well. Once the skid plate isn't holding up the transmission / transfer case, there's a lot of options for forming a custom skid plate.If one could weld, you could use something like the https://genright.com/products/universal-transmission-crossmember-kit.html and be able to gain about 2" of clearance without moving the case at all. Looking at mine, it would probably need a new, smaller muffler but other than that, everything else would stay as-is. Not a true tuck, I get that, but it certainly gains much needed clearance. You also do not need to hold up the case/trans for skid removal since the skid would then be separate. I need to learn how to weld
We did the stuff with a very heavy aluminum outer skin when we did Ricky's. The exhaust is right against the bottom of the tub and he says the floor stays cool.If you can, while you have it all down, clean the bottom of the tub and apply Dynamat Dynaliner. It has a reflective coating that radiates heat away from the tub and is a sound deading materiel. I have mine under the carpet, but wish I would have done it on the bottom when I had it all apart. I still may go back later and do it.
