T TJ._Danny New Member Joined Jun 5, 2023 Messages 2 Location Miami Jun 5, 2023 #1 I have a 2000 Wrangler Tj 2.5L 4 cylinder that I put a turbo on. I am also using a split second enricher. Do I need to use both o2 sensors or can I just use the first sensor. Also what colors are the cables for the o2 sensor reference and signal?
SkylinesSuck TJ Expert Supporting Member Joined Mar 28, 2020 Messages 4,348 Location Northern VA Jun 5, 2023 #2 You cannot tune with either factory O2 sensor. You need a wide band O2 sensor.
OP T TJ._Danny New Member Joined Jun 5, 2023 Messages 2 Location Miami Jun 5, 2023 #3 Do you know where I could buy the new sensor, and do you know what cables are the signal and the 5 volts of reference?
Wildman Over Analyzer Extraordinaire............... Staff Member Supporting Member Joined Dec 12, 2015 Messages 36,495 Location In the hills of WA Jun 5, 2023 #4 TJ._Danny said: Do you know where I could buy the new sensor, and do you know what cables are the signal and the 5 volts of reference? Click to expand... you have a few choices. AEM sells a gauge plus 02 wide band that also can be used for data logging. Zeitronis sells data loggers DynaJet also sells data loggers Innovative Motorsports is also a good option. I don't know much about Spit Second anymore. You need to install a map sensor designed for boost also.
SkylinesSuck TJ Expert Supporting Member Joined Mar 28, 2020 Messages 4,348 Location Northern VA Jun 5, 2023 #5 TJ._Danny said: do you know what cables are the signal and the 5 volts of reference? Click to expand... The factory service manual would tell you. It's available for download somewhere in the forum on a sticky thread.
Wildman Over Analyzer Extraordinaire............... Staff Member Supporting Member Joined Dec 12, 2015 Messages 36,495 Location In the hills of WA Jun 5, 2023 #6 https://wranglertjforum.com/threads...ice-manuals-fsm-technical-documentation.4618/
