Do we believe they are the same battery as previous?
Didn't Odyssey make them at one point? I'm going to assume that they are currently manufactured by East Penn because they look exactly the same as my Napa Legend AGM. I may be wrong though.
They're not the same as they used to be, Odyssey no longer makes them. My Diehard Platinum battery lasted 11 years, it was made by Odyssey who no longer makes them for Diehard.Diehards Platinum AGM are still available. They still get pretty decent reviews compared to others.
They're not the same as they used to be, Odyssey no longer makes them. My Diehard Platinum battery lasted 11 years, it was made by Odyssey who no longer makes the for Diehard.
I wish I could give you a stellar recommendation for something I know would solve your problem and I've dealt with enough of the various brands that I should be able to. At this point, I'd snag a mid range from some place with enough locations for an easy warranty exchange and call it a day. Less disappointing than having a 400 dollar battery crap out on you and a nice surprise if it doesn't.
What's your charge voltage? If you don't have a battery temperature sensor, there is a strong chance you are only charging at 13.7-13.8 volts all the time, which will quickly cause an AGM to permanently lose capacity. For an AGM, charge voltage needs to be in the range of 14.2-14.8V in most cases, with 14.4 to 14.6 being ideal at moderate temperatures. 13.8 would really only be appropriate at temperatures exceeding 150°F.
Flooded cell batteries are more tolerant of the low charge voltage, but will still lose capacity more quickly over time if they are not de-sulfated.
This thread has proven that batteries and battery sellers have some serious quality issues across the board these days.![]()
Depends on what time frame you are assigning to "these days". I've been dealing with the same AGM issues for at least 18 years. The only time it was highly lessened was when we could get the Sears Platinum Diehard.
Remind me again how you upped your charging voltage.
HP Tuners was what I hoped you were going to say. I'm going to poke around soon to up my charging voltage. Care to point me in the right direction?
