I have removed the nuts and tried to manhandle the doors off and sprayed PB Blaster. They do not budge. Are there any processes that might help me get the doors removed?
Try swinging the door and lifting it up at the same time. Pic shows bottom nut is still on?
Sometimes you gotta jimmyjam something.
Try not to pull up on handle end.
On my sons JK I loosened the nut a bunch, took a pole under it and on a floor Jack to push up, get pressure, and open close the door it popped loose.
Haven’t had that issue again.
Lift as close to the hinges as you can.
I also recommend lifting (from the outside) with the door closed as much as you can.
With the door closed? You lost me
Do your hinges look misaligned?(they are adjustable)
If they're bound up they won't want to lift out. My doors slide right out
“door closed as much as you can”
I think he means, not closed, but almost, meaning with the door close to being in the closed position, but not.
You got this! We’re cheering you on.
In other words, not wide open.closed as much as you can.
The hinges may have worn over the years.
Closed is where the door sits most of the time.
That's also the position when the door was aligned and the hinges were adjusted originally.
