Unique high RPM at idle
I don’t understand how I wouldn’t see that with a smoke test
when did you do the smoke test? If you did it on a cold engine, you might not see it. Since you describe it starting out at 1100 (which is about normal for a cold start) and then rising, it seems like something is opening up as it warms.
Thanks Freedom. I tested on a hot engine but not a running engine, of course.
The issue has been isolated to the aftermarket TB. Keeping the same gasket and sensors and switching only the TB I can fix and recreate the issue. I am working with F&B who made the TB.
Reactions: freedom_in_4low
FYSA this is my stock TB. I replaced the gasket after this test BUT I didn't have any idle issues before or after...this was just curiosity. I think I need to o-ring the TB. But don't want to break what doesn't need fixed.
That's because NTK no longer makes them.
They came up with a universal part that's basically with a longer wire or something...instead of two identical parts one with 6 inches more of wire.
What voltages are showing for the O2s in ODB live data? Anything below.9v generally and simplistically saying is a significant a good O2 sensor.
Also...the PCM doesn't change idle based on O2s.
It's either vacuum or your IAC...and since you don't have a stock TB perhaps that's the issue?
Your manifold gasket could have burned through in-between the intake and the exhaust ports. If it was leaking before then I would check it. Sealed at the edges but burned through in-between.
