Let's talk about up travel. What is it? When do we use it? Why does it matter? How do we preserve it? Do we want more of it?
Yes, assuming there is enough force (i.e. an obstacle) to continue pushing the wheel (and therefore body) up.
This is why I had mentioned that at some point you risk tipping the Jeep over on its side.
Hopefully my thought process here is correct.
Correct. Eventually, the rising wheel is also pushing the body over causing it to lean. A leaning body can create instability. Think about that with regard to LCoG builds.
Now, think about the turning into the the grocery store parking lot. How does this off road stuff apply on a daily driver?
Speed bumps, pot holes, dips on the highway, entrance aprons, washboards, dips and woops all benefit from suspension up travel. Give the wheels somewhere to go before they start shoving the body (and you) up and out of the way.If you're constantly hitting the bumpstops, even on small events, your ride will surely suffer for one.
We should take the body out of the equation. That is solved by different fenders, torches, sawzalls, and jig saws. After that, we have the chassis which has one end of the shock mounted to it and the axle has the other end.Speed bumps, pot holes, dips on the highway, entrance aprons, washboards, dips and woops all benefit from suspension up travel. Give the wheels somewhere to go before they start shoving the body (and you) up and out of the way.
It is not that difficult. It is just without some attention paid and possibly some alterations, that 50/50 split isn't really enough to let a shock do its job.It's tougher to get a 50/50 split than most realize, without alterations.
In the world of off the shelf shocks, like the commonly recommended Rancho rs5000x, do the manufacturers assume a ~50/50 travel split for their valving? There must also be an assumption on the vehicle weights that we could pay attention to and utilize. I'm thinking about ways people can better select shocks outside of the regular blanket Rancho or Bilstein recommendations.It is not that difficult. It is just without some attention paid and possibly some alterations, that 50/50 split isn't really enough to let a shock do its job.
In perspective, 9"ish travel shocks with 4.5"ish up and down are pretty common on the back of mildly lifted TJ's.
A travel distance for the ratio may also be an important detail. I bring up the factory 4" often as a minimum benchmark to maintain. But I do that mostly to encourage people to pay attention to what they are doing. It's clearly more complex than that, since most comfortable cars on the road have less suspension travel than a TJ.Was thinking the exact same question. Is a 50/50 split the "go to?" for shock makers?
They do have less travel, but they also have much less unsprung weight to deal with.A travel distance may also be an important detail. I bring up the factory 4" often as a minimum benchmark to maintain. But I do that mostly to encourage people to pay attention to what they are doing. It's clearly more complex than that, since most comfortable cars on the road have less suspension travel than a TJ.
