Upgrades needed to complete the Rubicon Trail
Roel Salazar
N.L. Mexico
Hi, guys, Im a 22yo mexican, and one of my biggest dreams is yo coquer the rubicon trail, so im starting saving money for the upgrades.
I have a 97 TJ Sport with:
-rear dana 44
- RC 2.5" lift kit
- 31" tires
- 2" coil spacers
The rest is stock
As You can see, its basically stock, so im searching for people who can tell me what upgrades I really need and the way to make it a budget build, because my salary its not that big to go 44" and a cummins swap haha.
Thanks.
Reactions: Apparition
I believe they are saying 33s these days are what is needed. I bet it could be done on 31s with stacking rocks but most jeeps/trucks/etc come with tires larger than 31 from factory these days.
You can do it in a bone stock Rubicon with the right driver and a good spotter.
All I would really insist on is a winch, lockers, and good tires.
. . . one of my biggest dreams is [to conquer] the Rubicon Trail, so I'm saving money for the upgrades.
. . . I'm searching for people who can tell me what upgrades I really need and the way to make it a budget build. . . .
The Jeepers Jamboree has been organizing runs across the Rubicon Trail for 53 years. This is their recommendation:
  • At least a 3.5" Lift and 33" Off-Road Tires
  • Functional parking brake or micro-lock
  • Tow Strap with loops (recommended rated at 2 times the vehicle weight)
  • First Aid Kit
  • Hi-Lift Jack (you might need one for changing a tire)
  • Spare tire with diameter within 3 inches of existing tires (no temporary spares)
  • Battery Hold Downs (no bungee cords)
  • Skid Plates for gas tank, transfer case and transmission
  • Remove all Hub-Caps and Steps
  • Must have functioning low range in transfer case
  • Locker in front or rear
Suggestions: 5 gallon can of gas for older vehicles and rocker panels for more protection.
This is their pre-departure maintenance checklist:
  • Check Engine Oil
  • Check Transmission Oil
  • Check Brake Fluid
  • Check Radiator Coolant
  • Check Water Pump (if accessible)
  • Check Ignition related items
  • Check for proper Alternator output
  • Check Battery will charge, hold a charge, and battery hold down supports the battery
  • Check fuel system along with hoses for cracks and leaks.
  • Check Fan Belts
  • Check Hoses
  • Check Power Steering system components
  • Check Air Filter
  • Check SEAT BELTS
  • Check Tires for wear or damage
  • Tighten drive shaft u-bolts
  • Check and tighten lug bolts
  • Check for CRACKS IN FRAME
  • Check brake pads & shoes
  • Check for loose bolts or nuts all throughout the vehicle
  • Grease all fittings (u-joints, steering)
  • Check gear oils: transfer case/differentials
  • Check Shocks and Springs
  • Double check winch and cable
Careful thought and many years of offroading experience on the Rubicon Trail are reflected in both lists.
