Just replaced my water pump, I havent started the Jeep yet. I just filled it with water to check for leaks and immediately water started leaking from the upper rad house at the top of the thermostat.
I have the hose right above the tab and the clamp is aligned in the same spot where is grooved into the hose.
Tension seems good on the factory clamp.
New clamp, new hose? What did I do wrong, you know, other than owning a rusted out TJ for the last 5 years.
