Getting ready to replace my radiator and do a general cooling system overhaul (sans water pump). Got a new water outlet, and as the title says, I'm not sure what if any gasket sealer to use on the gasket.
Thermostat housing. It has a gasket, but there is always some debate as to what kind of sealer may or may not be necessary. It's one of those thick paper style gaskets.What are you calling water outlet? Gaskets are the way to go on the cooling system.
Paper gaskets work fine/great, that's what the factory uses. I cut an emergency thermostat housing gasket out of a cardboard MRE box on the trail and it worked perfectly fine, no leaks. I didn't bother replacing it for several monthsThermostat housing. It has a gasket, but there is always some debate as to what kind of sealer may or may not be necessary. It's one of those thick paper style gaskets.
