Wavian Jerry Cans Arrived
Moglocker
St.Augustine,florida
Got a couple (they are going fast)didn’t include adapter for my tj,what is everyone doing.end is too big to fit-thanks
That nozzle will start leaking soon, right where the plastic meets the metal, happened to me and many other reviews mention it. I'd suggest buying a flexible one.
Made this from a Wavian water can spout mainly to make it easier to fill a generator, chain saw, etc.
Its simple as well to use when filling a vehicle. The tube fits an unleaded fuel opening
If you go this route remember to change the gasket to the fuel rated version.
I have this one with a Wavian brand name clearly on the plastic and it works perfect on a 2004. I don't know where you guys got yours but mine looks different and works fine. Maybe they changed the design or you got a different deal?
I have a couple of the flexible spouts. It works good but they will leak a little on a vent hole at the base if you tip the can too far up.
Wavian Long-Nose Flexible NATO Jerry Can Spout/Nozzle (Olive Drab) https://www.amazon.com/dp/B07WZV8442/?tag=wranglerorg-20
I also have a jiggler hose. It’s awesome if you have your cans on mounts higher than the filler hose.
The Original Safety Siphon 10 Foot High Grade Hose, 1/2" Valve Siphon - Self Priming Pump Transfers 3.5 Gallons of Liquid Per Minute - Great for Pools, Fish Tanks, Fuel, and More https://www.amazon.com/dp/B01MZ76L3Z/?tag=wranglerorg-20
