Weak starting issue
Codom82
Poplarville,ms
My 99 jeep 2.5l is weak starting. The battery is 3 months old. Starter has been tested several times and the alternator is charging. Any ideas on what the issue could be? I've cleaned the grounds and checked all the connections.
DWR
Georgia
Just for clarification, weak as in it sounds like it’s having a hard time turning the motor over? Also this might be one of those circumstances that a short video may help.
In the meantime, check the ASD relay/fuse (I think it’s called), really may be on it’s way out.
TJ4Jim
TJ Expert
Lifetime Supporting Member
Brookings, Oregon
Take a good look at the positive cable to the starter checking for anything that looks odd, given the right conditions the cable can corrode internally.
Gilaguy23
New Mexico
Put a volt meter on the battery when your cranking it over and see how voltage drop you get. A normal battery should be at 12.6 V more less. Not saying your starter is bad but most of the knuckleheads at the likes of Kragens or Autozone couldn't tell the difference between a turd and hunk of mud. Why yes...it spins..must be OK then.
C
Codom82
Poplarville,ms
My battery was at 12.83 when trying to start. It drops to 11.4.
C
Codom82
Poplarville,ms
Weak as in the starter doesn't have enough power to turn the motor over. No clicking what so ever.
C
Codom82
Poplarville,ms
So I changed the battery and it's still doing the same thing. Starter should be in today. If that's not it what else could it be?
