how does a TJ on 35s with a 101" WB and raised belly do on those trails?
Just fine.
Bummer to have our great spotter in the way of the rig, but it was the only safe/“out of the way” place to stand on a tight/steep portion of the trail. In any case you can sorta see the rig articulating and working pretty well on a fairly big obstacle. Our AdventurePig is definitely more rig than i am driver…lol. I have a lot to learn still.
what trail?
I never rotate the steering gear, the juice isn't worth the squeeze. Not only do I not do it, I won't, not even for money.
DW is caused by components that are too small or too worn to handle the propensity for out of balance or out of round tires to precess. As the components increase in size and strength, the easier it is for them to mitigate the precession.
The only part of your steering that is parallel to the axle is the tie rod. Straight and true driving is a function of a lot of things. I routinely build TJ's on 35's with Haltenberger that drive exceptionally straight and true with everything in the stock but beefed up configuration.
Most of your end result is a function of what is now a 10,000 dollar front axle. Us mere mortals have to find other ways to make it all work.
They are not because they can't be. The draglink is at an angle as is the track bar.I assure you all my connections are parallel to the axle, that was my engineering thinking.
I was guessing based on what I know prices have done in the last several years. This is for a JK, I don't imagine the TJ version will be much if any less since there is no reason for it to be.It was then that I decided to redo my suspension on my Dynatrac Pro 60, I don't think I paid $10k it's closed, IIRC.
It would be sad if he sold to a normal company. It is way more than sad that Yukon is the new owner.My Jeep was featured in the Dyantrac catalog for several years. I knew the owner really well, great guy. It's sad to see that he sold out to another outfit.
And again, that is a function of size and strength.After I redid the suspension, I did not have an issue with DW again, and for about another 5+ years and a good 50-60k miles. That is when I was living out in Scottsdale, AZ, and we talked a lot back then.
This is the axle in a box. You will still need another 5 grand in steering and fab to get it under a TJ.
What’s your recipe for a Jeep that does all things reasonably well?
1. Daily drive 65mph on the road
2. Road trip a reasonable distance
3. Handle 6-8/10 or higher rated trail without breakage
4. Family hauler
5. Grocery getter
6. Etc…
What model/trim, what drivetrain, what year, and what mods are you choosing?
4. Family hauler
5. Grocery getter
6. Etc…
Perfection is an elusive goal. Even with unlimited funds, every build is a compromise. Pick your priorities and build around those. What's most important is for you to enjoy sitting in the seat and turning the key. Anything beyond that is a distraction that will likely have you chasing your tail in pursuit of an unattainable end state.
Yup, i’m an admitted tail-chaser. I appreciate this post.
