I was just wondering what the power specs are for the ‘02 factory stereo. Looking to upgrade and I want to make sure I am well above the factory watts.
Interesting since I just replaced the speakers. Both pairs are 92dB. So I am walking in the tall cotton!The factory stereo puts out 6-8 RMS watts per channel. Make sure any new speakers you install have a Sensitivity rating of no less than 90 dB. If you buy one with less of a Sensitivity rating you'll require a really high wattage aftermarket amplifier. Pay no attention to the speaker's wattage rating they scream in big letters in their ads or on the box, that's just the max power they can accept from the amplifier without blowing up. The problem is the Sensitivity rating is usually buried in the speaker specifications.
A 3 dB Sensitivity rating makes a HUGE HUGE (!!) difference in how much power a speaker requires. It takes twice as many watts to produce the same volume with a speaker with an 87 dB Sensitivity rating than it does with a speaker with a 90 dB sensitivity rating. Speakers with higher sensitivity ratings like 90 dB and higher are a little harder to find but Kicker and Polk's DB series have speakers rated with a 90-92 dB Sensitivity rating.
https://www.crutchfield.com/p_108R6432CM/Infinity-Reference-REF-6432cfx.html?omnews=16810957https://www.crutchfield.com/p_108R5032CM/Infinity-Reference-REF-5032cfx.html?omnews=16810957
A big improvement over the tired original speakers.
Thanks for the info!
Thanks for responding; I need a new set of stock replacement speakers to go with my stock CD player. I would like to hear your opinion of these. They look good and are cheaper than what I was looking at. Are they much better than your stock speakers? Did you have to wire these in, or did they come with correct plugs already on them?
I was looking at these replacement Kickers from Quadratec that already have the factory plugs on them:
https://www.quadratec.com/products/14133_2X0_PG.htm
https://www.quadratec.com/products/14133_2X1_PG.htm
I don’t know enough about speakers in general to give an opinion on those speakers. I do see they are nearly twice the price. so
https://www.crutchfield.com/p_206DSC504/Kicker-43DSC504.html?omnews=16810957Thanks for responding; I need a new set of stock replacement speakers to go with my stock CD player. I would like to hear your opinion of these. They look good and are cheaper than what I was looking at. Are they much better than your stock speakers? Did you have to wire these in, or did they come with correct plugs already on them?
