Oh sure, sludge is good stuffIf the crud is settled enough that you have to dig it out, that's a good thing right?
As usual Jerry is very correct ! If your going to do a job take the time to do it right!X2 to those recommending you pull the cover when changing the gear lube. Only then can you see if there's any damage to the gears or if there's metallic reside laying in the bottom of the housing.
This job is not time consuming enough to feel the need to rush it by resorting to sucking the old gear lube out which doesn't get the bottom debris out.
If the metal particles are stuck in the sludge, they aren't circulating through the diff, right?Oh sure, sludge is good stuff
Suppose that depends on how solidified the sludge is. In the 200+ vehicles we've had plenty of them have a good 1/4" recessed belly in the diffs that oil will not drain from so a simple rag or skinny finger gets it cleaned out of any remaining oil or debris laying there. But you knew that of course. Ya think you get 100% of the engine oil out when you pull the plug on a pan? No, not even close is my point.
How often are you changing the gear lube?Is it sufficient to pump it out every other service interval? I’ve always just removed the cover, but would like to know.
Every 13,000 milesHow often are you changing the gear lube?
I’ve got 24,000 miles on the gears. I can see your point about water possibly getting inside. The inner diff seals should stop that though, right, under normal usage, water crossings up to the headlights.On a street driven vehicle I'm totally on board with that. But my wife's 4runner has a drain plug, go figure.
But when I think about my Jeep, there's a lot of situations that make me want to pull it. Like the fact that my gears aren't factory, and are still pretty fresh. Or if I go through a water crossing above hub depth, I don't want any water getting left behind. Or that with my tuck and SYE, my axle is rotated up so high that I have to go by volume through the vent tube to fill it, and if I'm not sure how much I could have left inside, I don't really know how much to add.
I think schedule B in the service manual calls for something like a 12k mile interval. If your gears are established and you haven't done anything that could contaminate it, I don't see how it could really hurt.
I used to work at a garage when I was a kid. We used a vac pump to suck oil out of diffs all the time. If it wasn’t leaking, no reason to pull the cover. Way faster too. You won’t get all the oil, but 99% of it.
