Please bear with me as I'm not mechanically inclined and a lot of this is new to me.
I have a 06 LJ, 4.0, auto on 33's on an unknown lift. I assume it's a 4 inch lift, and I do not know the brand. I do know that after I put a bumper and winch on, the front sagged noticeably and now I have quite a rake.
I'd like to know what the previous owner has done my jeep, and why. After that, if it's wrong, and I suspect somethings are, I'd like to start correcting and upgrading things with quality parts. The end goal would to be a medium-duty Jeep that will eventually run 35s. I don't give it hell at all, but I'd rather be overbuilt than under. I'm currently on 33s and bigger tires would probably be the very last thing that was done. (right)
Transfer case drop.
I noticed that the transfer case skid was lowered. For a while I thought this was normal until I saw someone elses. Is this necessary? It's pretty hangy downy and I'd rather it not be that way. I assume this was done to prevent driveline vibrations? Would this require an SYE to remedy? I thought I had read that LJ's didn't need SYE's but maybe I'm misremembering.
Does this look right?
Is this a MML?
Dropped pitman arm
This is a dropped Pitman arm, correct? It also looks like the stock mount for the track bar. Looking straight ahead, the track bar and drag link are parallel. The steering wheel is centered, the jeep tracks straight, and when I hit bumps, it doesn't want to jerk the wheel or want to go left or right, it pretty much stays straight. Does any of this need to be changed? Thought about getting a heavier duty tie rod since I read it was recommended for 35s which will eventually be put on.
(Yes, I know my steering stabilizer is faded and pink)
If anything else looks out of wack, please let me know, because I can assure you I probably don't realize it.
Oh, and one of the first things I'd like to do is improve the ride quality and fix the front rake. I know of some Currie 4" springs that are about to come available. I was thinking about getting those and some new shocks. Seems like the Rancho RS5000X's are popular.
Thanks.
Transfer case drop.
Is this a MML?
Dropped pitman arm
Thanks.
