Hope you all were ok. Tj looks a little worse for wear.
Amazon suckered me in with a limited edition less than 10 left blah blah Factor 55 winch nipple. Now I need a chrome roller fairlead to keep it from clashing with the Warn logo. Should’ve put more thought into that...
Started working on some rubber spacers to elevate my seat. Inspired by Rollin20z rubber mallet mod I cut up one of my rubber bumpers that I cut off Ripley’s front bumper to make 4 pcs about 1.25 inch square x 2 in long. I very carefully used my table saw. Will post pix.
Replaced my right front a few months ago. Not too bad.
Pulled over on the side of the freeway to put the top back together. LOL I was going down the freeway and looked back and my rear corner of my top was flapping in the breeze! I was running with the Bestop sunroof back and no windows. Got pulled over to put the corner back in and noticed it pulled down way to easy. I looked to see if the mid section was pinned in, and noticed the pin was completely gone. I had to close the sunroof to continue on my way.
I just got done emailing Bestop to see if they can send me a new pin, actually 2 I want a spare. Going to suck not being able to use the sunroof. LOL
Driver side pin now missing in action. LOL
Pin I'm talking about. (passenger side).
I was going to put a bolt in it for now, but I found out that I can't. The hole doesn't go all the way through. I hope Bestop will take care of this and fairly fast. I will have to put the top down all the way to go topless and I really like just running the sunroof.
I would be concerned with proper torque.I think I’ve seen a post somewhere where someone used rubber as seat spacers and they split.
Take a look inside the bump stop mount and clean out any dirt and rocks that may have accumulated.
Nice skid. Why is there only 1 bolt going into the frame on the bumper brace?
wow mate..!!! are you ok ?
Ouch! What happened?
Unfamiliar gravel curve, disconnected sway bar, and tires at about 15psi equals sliding sideways hitting the ditch and rolling probably about 4 times. Neither me nor my cousin were wearing seatbelts and were ejected on about the first or second roll. Snapped both bones in my left arm and a couple lacerations on my head. So in my arm went to 2 metal plates and 12 screws and my head got 12 staples(removed today). My cousin has a fractured L1 vertebrae and also a few cuts with stitches. So he has a back brace and had been walking with a walker but today started walkim a little bit without it(YAY!).TJ is obviously totalled.Hope you all were ok. Tj looks a little worse for wear.
Unfamiliar gravel curve, disconnected sway bar, and tires at about 15psi equals sliding sideways hitting the ditch and rolling probably about 4 times. Neither me nor my cousin were wearing seatbelts and were ejected on about the first or second roll. Snapped both bones in my left arm and a couple lacerations on my head. So in my arm went to metal plates and 12 screws and my head got 12 staples(removed today). My cousin has a fractured L1 vertebrae and also a few cuts with stitches. So he has a back brace and had been walking with a walker but today started walkim a little bit without it(YAY!).TJ is obviously totalled.
But thank God. We have a lot to be thankful for also. Lots of accidents like this don't end up near as good.
