I checked this week-averaging about 17mpg combined on a '98 Sahara with 5 speed and entirely stock height tires/gearing/suspension. Most of the driving is in town with some highway, probably a 75/25 split, respectively.
I had a 19 gallon tank factory but previous owner must have swapped it to 14 for some reason. I am just curious how many miles other TJ owners can expect in a tank.Not sure why people want to compare miles per tank? Everyone fills up at different times. Can't trust the gauge.
Figure out your mileage based on miles per gallon; and know your tank size (14 or 19).
Jamison C said:I had a 19 gallon tank factory but previous owner must have swapped it to 14 for some reason. I am just curious how many miles other TJ owners can expect in a tank.
Again, was not writing this thread with the intent of calculating my own gas mileage. I am already aware of my mileage in my TJ. My reason for posting this thread was simply because I was curious what other TJ owner's were expecting out of their jeeps. Everyone's will relatively be different or else what would be the point in me asking. Also yes I have ran my TJ bone dry out of gas before and it filled up no more than 14 gallons.It's not rocket science.
If you calculate your mileage by dividing known miles by the gallons that you put back in to fill up, and you know your tank size (not guess), then you can calculate the range (miles per tank) for your vehicle. Knowing someone else's guess does nothing for you.
I usually go about 280 miles between fill up, and the fill up is around 16 gallons, give or take.I had a 19 gallon tank factory but previous owner must have swapped it to 14 for some reason. I am just curious how many miles other TJ owners can expect in a tank.
I though my TJ was slowI get around 15 MPH, Never really on the high way so all city driving.
I have a 6 cylinder but my jeep only holds 13-14 gallons max when it is completely empty. I always thought the previous owner before me had swapped out the fuel tank but i see no reason he would do that. Do you think it is possible my 6 cylinder somehow has this modification in the fill tube?All TJs came with 19 gallon tanks, but 4cyl models had a modification in the fill tube to only accept 15 gallons. This is easily reversed by cutting back said tube. I assume this had to do with shaving weight after filling up.
The PO could have damaged the original tank on a trail and just replaced it with a 4 cyl one. I didn't read the "how to" on the hose thing, but it looks pretty easy. You might be able to unscrew the hose and just check the length.I have a 6 cylinder but my jeep only holds 13-14 gallons max when it is completely empty. I always thought the previous owner before me had swapped out the fuel tank but i see no reason he would do that. Do you think it is possible my 6 cylinder somehow has this modification in the fill tube?
That is possible but I don’t think he wheeled it much because it was bonestock when I purchased it from him. Not sure though, thank you and I’ll definitely research that.The PO could have damaged the original tank on a trail and just replaced it with a 4 cyl one. I didn't read the "how to" on the hose thing, but it looks pretty easy. You might be able to unscrew the hose and just check the length.
Thats pretty piss poor mileage!I have 31's and im assuming a 19 gallon take as that's what i use to calculate this, 6 speed manual. I'm getting around 11-13 miles per gallon, but I'm assuming that my speedometer is off by around 10% because of the larger tires.
In a month or so ill install a 3.5 inch lift and put 33's on it, ill report back then to what im averaging.
let see there's 2 pints in a quart, 4 quarts in a gallon......how many gallons in a watt IT'S NOT THE MPG IN A WRANGLER, IT'S SMILES PER GALLON ! i get about 50It does make me wonder how a full electric Jeep would work. If they estimate 50 miles on the battery for the new 4XE, I wonder if you would get 45-50 all offroad usage or not.
Mod is not to the fill tube but rather the vent tube. The early SE's fuel tanks had the vent extended lower into the tank which shuts the fuel nozzle off earlier. It just has to be shortened internally.That is possible but I don’t think he wheeled it much because it was bonestock when I purchased it from him. Not sure though, thank you and I’ll definitely research that.
My fuel economy went up a bit after I started to change at higher revs as suggested by a few on here which sort of went against my logic but it worked!Ha yeah its pretty bad! I'm new to manual transmissions though so maybe that could be a reason. I try to keep it between 2-3k at most times though.
I know my speed is off dude the tires its off by around 10% as the miles get bigger, so that would equate to around 13-16 mpg. I thought TJ's averaged about 15 mpg.
