I've been trying to figure out what is causing body sway on my 1999 TJ with a 4" suspension lift and 31" tires. I had a 2002 with a 4" suspension lift and 33" tires in the past and never had this problem. It doesn't matter what speed I'm driving or if the road is smooth or has potholes. The body rocks side to side. The first things I noticed is the rear sway bar had some side to side movement on the bushings. Replaced those and didn't help much, rear lower control arm bushings were shot, replaced those and that still didn't help, The only thing else I see is the front sway bar end links have some free play in the bushings. Would that cause the issue?
