So I've searched around a bit and found some info on jaguar forums, but nothing TJ specific. It seems like Open Loop-Drive is a mode the computer may switch to during heavy acceleration where it sets fuel output to max. I'd like to get a bit more clarification on that.
This is all on a 2002 TJ with the 4.0 and 32rh. Basically a stock motor, no tunes or add ons. Several months ago I had to replace my cats, used the flowmaster kit and redid my exhaust setup at the same time. Had to fiddle with how rigid my mounting was and I may have caused a new manifold leak in the process, but I have several small leaks at the head.
A month or so goes by and my mileage seemed to be getting worse, went ahead and did new plugs (autolite iridiums) and NGK O2 sensors. Didn't seem to help, kept driving it. Then it threw a code, scanned it and it was a cam sensor code. Replaced that and still no change. Kept using my coworkers scan tool to monitor O2 sensor voltages while driving and they all seemed to be normal.
That's when I noticed the computer would start in OL when first started and switch to CL in about 15-30 seconds. It remained in closed loop while driving except when I'm cruising on the highway. I'm geared with 4.56's on 33's so my RPM's are a touch above stock. I turn about 3200rpm at about 65mph. If I cruise at 3k it stay on CL, but if I need more gas for an incline or just go faster, when I hit 3200rpm or about 45% load on the scanner it will switch to OL-Drive and stay there until my RPM's drop again.
Does anyone know if this is normal behavior? I'm not finding any mention of it anywhere regarding a stock motor, seen a bit with regards to custom tunes on different motors. I'm wondering if this might be a cause of my mileage, but idk how long it has done this. The motor seems to run the same as always and that cam sensor code is the first code I've ever thrown in 100k miles. Probably put a couple thousand on it since I discovered this and it's been fine
