Hi
the specifications give: 0.005 <backlash <0.009
I thought I had found the right setting, I'm disappointed
Do you think No. 7 is better than No. 6?
What should I change in my setting?
Thank you for your help
PS:
I have already used a pinion and crown with the settings of post 7
after 600 miles see photo
je me suis mal exprimé
Mon premier réglage était celui qui correspond à la photo du message # 7,
mais ce n'était pas bon.
Quand j'ai ouvert le différentiel j'ai vu ça:
que manque t'il dans mon réglage pour que ce soit bon?
I misspoke
My first setting was the one that corresponds to the picture of message # 7,
but it was not good.
when I opened the differential I discovered some scratches on the crown, the imprint corresponds to the message # 7
For a Dana 35C the Backlash must be between 0.005 "and 0.009" (manual)
